Hi everyone,
Has anyone experienced this issue before? Currently, IC is loading the Cabinet 3D tool extremely slowly, with a waiting time of almost 10 seconds (it used to be quick).
When I click the tabs, it is also very slow to respond. This problem started a few weeks ago, not long after a Windows 11 automatic update. Does anyone know of a solution for this issue?
Thanks
Nap
1 hour ago kingchaos wrote:
i dont got win 11 so if tis related to it, i dont have it.
Hah... Window 10 is good, Win 11 is overly complicated.
I am not sure if the issue is coming from Windows 11 or VW24 SP5 or from others.
I have reverted from IC24 SP5 to IC24 SP4, but the issue is still unresolved.
Hello Napwszzm,
It takes me 4 seconds to open the corpus generator. Windows 11 and VW 2024 F5.
The tabs are very quick.
Is it possible that you have a material in the corpus generator (constratction) that does not exist in your master data?
This slows down the corpus generator extremely.
Best regards, Günther Sedlmeier
Vectorworks 2026 interiocad mit Architektur
Windows 11 64 bit
vor 24 Minuten schrieb Marcel Ostendorf:
Hi there! Maybe it's just the document which is corrupt. Have you tried it in another file?
Hi Marcel,
I tried multiple times with a new file, there is no difference. I will try other ways to see if I can resolve this issue.
Thanks,
Nap
vor einer Stunde schrieb gsedlmeier:
Hello Napwszzm,
Hi, thanks for your reminder.
You might be correct, an you have reminded me of something.
I created a file on my home computer and then opened it on my office computer, where I noticed it was quite slow.
Do you have a hint about which folder on the C drive I should inspect to delete the "constraction" file?
I have a feeling that the issue might be related to a material.
Thanks for your input.
Nap
After doing some research online and some experiments, the issue still unresolved. I suspect that the issue is coming from the latest Win11 23H2 update. It's sad, there is no easy way to revert it back to 22H2 without a new installation.
Hi Nap,
I have win11 23H2.
You won't hear me saying the corpusgenerator is fast but it definitely isn't as slow as on your video. It takes 5 a 6 seconds to open. Tabs are fast. So I don't think it's related to that update.
vor 16 Stunden schrieb bertf:
Hi Nap,
I have win11 23H2.
You won't hear me saying the corpus generator is fast but it definitely isn't as slow as on your video. It takes 5 to 6 seconds to open. Tabs are fast. So I don't think it's related to that update.
Hi Bertf,
Thanks for your input here. It's quite annoying when the Tabs loading is slow. Both of my two computers are having the same issue.
      26,9Tsd
      139,7Tsd
