Help Needed Importing & Using SwissALTI3D GeoTIFF in Vectorworks Landmark 2024 (Bitmap)
s.shmaguina
Hi everyone,
I'm a landscape architect using Vectorworks Landmark 2024 and I'm having trouble extracting elevation data from a swissALTI3D GeoTIFF file that I've imported as a bitmap.
Here's what I've tried so far:
  • Importing as an image and attempting to use the "Extract Elevation" tool (not available in my version)
  • Trying to import as a terrain model (option not found in my version)
The "Terrain" toolset is also not visible in my workspace. I've tried resetting workspaces and manually adding toolsets, but no luck.
Is there anyone familiar with Vectorworks 2024 who can guide me through the correct steps to extract elevation data from a GeoTIFF bitmap? Any help would be greatly appreciated!
Thanks.
Im not familiar with the landcape module in Vectorworks. But i had to do this several times in the architecture version.
Doesnt work directly in Vectorworks. You need to import the Geotiff into QGis. Then with the Contour Tool you can extract the linies, after you can do the command Add z-Values with the variabel ELEV which puts the height into the contours. Next export as DXF and import in Vectorworks.
Ich hinterlasse das mal hier für alle, die in Zukunft nach einer Antwort suchen:
Alternativ zu der oben beschriebenen Methode, die Höhenlinien in QGIS zu extrahieren, bietet sich folgender Workflow an, den ich persönlich besser finde, weil die vollen Originaldaten in die Vectorworks-Datei kommen.
- GeoTIFF in CloudCompare (cloudcompare.org) öffnen
- bei Bedarf mit Edit > Subsampling die Punktdichte verringern
- Save > ASCII cloud (*.txt)
- Die resultierende Textdatei in Vectorworks per Import Aufmaß/Koordinaten als 3D-Punkte importieren
- Aus 3D-Punkten Geländemodell anlegen
Bearbeitet von linosphere
  • Like 4
Vectorworks Landschaft 2024
Es gibt auch noch die Möglichkeit bei Schritt 3 eine Punktwolke im Format e57 zu speichern, dann Import Punktwolke in Vectorworks und aus der Punktwolke direkt das Geländemodell. Bei der Variante von linosphere könnte man einzelne Punkte die man nicht mitrechnen will, einfacher weglöschen, dafür ist die Punktwolke bei sehr grossen Daten aus meiner Sicht schneller.
Vectorworks Switzerland
An gleicher Quelle gibts auch das xyz-File welches die gleichen Daten in einem für Vectorworks lesbaren Format speichert. Die kann man als Punktwolke importierten und dann zum GM umwandeln.
Generell würd ich wenn immer möglich auf die Geoportale der Kantone gehen. Da gibts die Punktwolken in noch höherer Auflösung.
      26,9Tsd
      139,7Tsd
