napwszzm Geschrieben 14. April 2022 Teilen Geschrieben 14. April 2022 vor 1 Minute schrieb kingchaos: i know where it is, but i dont know all the details about this function For example you created the Set A on the 1st Jan, but you modified the material in that Set A saved on the 2nd of March, the Set A could saved the old texture/material. If this is the case, you should update all the edge material in the window, and save it as Set A-V2 somthing like this. I hope my explanation can give you a bit more details. 1 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
kingchaos Geschrieben 14. April 2022 Autor Teilen Geschrieben 14. April 2022 as i said "it could" i am going to cry ^^ "it could" is nothing i can deal with HP Z6 G4 Intel(R) Xeon(R) W-3223 CPU @ 3.50 GHz - NVIDIA Quadro RTX 4000 VWX IC 2023 SP7-F7 R1 Windows 10 64 GB 64 bit Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
napwszzm Geschrieben 14. April 2022 Teilen Geschrieben 14. April 2022 vor 2 Minuten schrieb kingchaos: as i said "it could" i am going to cry ^^ "It could" is nothing I can deal with It seems @Jodak has already answered your question. Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
kingchaos Geschrieben 14. April 2022 Autor Teilen Geschrieben 14. April 2022 yes and i have to correct it via presets, so i told u i did not use this presets at this time ever before and i will have to learn. But maybe there is some unwanted behavior while i use it and my way of doing things would be fundametally changed, HP Z6 G4 Intel(R) Xeon(R) W-3223 CPU @ 3.50 GHz - NVIDIA Quadro RTX 4000 VWX IC 2023 SP7-F7 R1 Windows 10 64 GB 64 bit Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
napwszzm Geschrieben 14. April 2022 Teilen Geschrieben 14. April 2022 vor 1 Minute schrieb kingchaos: yes and i have to correct it via presets, so i told u i did not use this presets at this time ever before and i will have to learn. But maybe there is some unwanted behavior while i use it and my way of doing things would be fundametally changed, ok, it sounds you have a clue to solve the problem, that's good. The "Preset" function is quite helpful if you want to change materials quickly. 1 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
kingchaos Geschrieben 14. April 2022 Autor Teilen Geschrieben 14. April 2022 yes, and there was a preset, what i did not know and know know what it did to my parts so it was not good to have a preset, that was what i called "unwanted behavior" so i did not experimented with it. at this time i dont need to be fast, i need to be accurate and save and make some rules for my collegues, that they dont make some mistakes they cant find or solve. The speed will be come later on. HP Z6 G4 Intel(R) Xeon(R) W-3223 CPU @ 3.50 GHz - NVIDIA Quadro RTX 4000 VWX IC 2023 SP7-F7 R1 Windows 10 64 GB 64 bit Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
