Hello team,
I would like to ask is it possible to refresh/update the material thickness in Interiorcad quickly?
What happen was I entered the incorrect board thickness (18.4mm) in the material master data a while ago, but the right thickness should be 18mm, not 18.4mm.
I used 18.4mm thickness to build approximately 27 cabinet models, so I want to know is there a quick way to refresh/update the old cabinet panel thickness to 18mm?
I know I can open each cabinet and change each panel thickness, but it' is very time consuming.
So is there a quick way to make this easier?
Thanks a lot.
Nap
I cannot see a problem there. Here's what you do:
  1. Enter the new thickness in the Master Data dialog.
  2. In the "Construction"-pane of the interiorcad cabinet edit dialog, re-enter the material (delete the last digit of the material name, then re-enter it).
  3. Repeat for all parts
  4. Save as a set
  5. Apply the set to all cabinets that you want to chance. You can use the menu command "Construction" under the interiorcad menu for that.
Stephan Mönninghoff wrote 4 hours ago:
  4. Save as a set
Hi Stephan,
Thanks a lot for your quick reply.
I was looking for an idea (or a way) for updating/refreshing the old cabinet library (cabinets saved in library preset) panel thickness without opening and editing each of them.
It would be good if there is a way to refresh the whole old library cabinets when panel thickness is changed.
I did try the command "construction" under the top interiorcad menu, and it's working. However, when I start a new job and use the old cabinet library in "custom defaults", the old cabinet panel thickness still 18.4mm (wrong size), not 18mm (new size).
I was wondering if there is a quick way to update or refresh the old cabinets panel thickness without editing them and save them.
Also, is there a quick way to save the modified cabinet?
For example, I made a cabinet "Birch Test" marked in A at first, and then I made a changed on it, and now want to update the old cabinet A without changing its name.
What I normally do is to save it as "Birch test 02", then delete the "birch test", and then name the "brich test 02" back to "birch test". I am not sure if I am doing the right way to update the existing cabinet in the library? Please do show me a quick way to update the existing cabinet if you have one.
Many thanks again.
Nap
Bearbeitet von napwszzm
duplicated picture
vor 2 Stunden schrieb napwszzm:
Ah, gotcha. Good point. I don't think we have a way to do this without overwriting each cabinet in the library individually. But I will make a note to add this when we revise the way that materials are handled. No promise as to when this will happen, except that it will.
vor 9 Stunden schrieb Stephan Mönninghoff:
Hi Stephan,
That sounds good. Hopefully the overwriting function can be improved soon. I understand that it involves lots of work to inspect programme coding etc., especially for handling Apple OS and Windows platforms.
I posted a question last month regards to the drawer runner/holes misplacement in Vectorworks.net. I have done some experiments since then, and figured out what was happening on my Windows version Interiorcad. Please see below experiments:
First, I created a new file "untitled 1".
Second, I opened the cabinet A (same as B) in the symbol preset from "Master Library", please notice that the "master library" is the one I store my kitchen cabinet models.
Third (this is the problem coming from), I changed the cabinet size, in the red colour highlighted box, from 450mm to 600mm or 900mm, then drawer/drillings displacement happened in cabinet A.
Fourth, I edited the cabinet width either using "setting", "reshape tool" or right click mouse "edit", the cabinet B looks all good.
So, it looks to me that the red box A parameters might need to be revised or make it consistent to "settings" or "edit".
I am not sure if this only happens on my side, or someone has experienced this problem on the other platform.
Now, for avoiding these problems or potential issues, I normally duplicate the "master library" and the name is to customer file say "John Kitchen/Project", for making sure all cabinet settings are coming from the same root library/settings.
Thanks again.
Nap
Am 2.9.2021 um 02:09 schrieb napwszzm:
Hi Stephan,
Thanks again.
Nap
Interesting. Can you send me the library file and, if it is not too much trouble, a short movie to help us reproduce the steps required to trigger the behaviour? Please use our ticketing system for this: https://en.extragroup.de/submit-ticket/
I will have a look what is happening.
Thanks for the detailed description!
      141,2Tsd
